TwinTurbo.NET: Nissan 300ZX forum - It may run, but no, it won't run well. (n/m)
Nate (NoVA)
on July 31, 2014 at 12:33 PM
Can a Z run "well" on only 5 cylinders?
posted by Z32CheekiBreeki
on July 30, 2014 at 11:52 PM
Z32CheekiBreeki
23:52:09 07/30/14
It may be the injector. How does the exhaust smell? (n/m)
ZaXxon
04:16:00 07/31/14
It may run, but no, it won't run well. (n/m) -
Nate (NoVA)
12:33:11 07/31/14
If the injector is intermittent, you risk a lean condition..
Ted (92TT)
14:04:37 07/31/14
Re: If the injector is intermittent, you risk a lean condition..
Z32CheekiBreeki
12:11:59 08/01/14
Swapping plugs seemed to move the problem!
Z32CheekiBreeki
12:56:57 08/01/14
Re: Swapping plugs seemed to move the problem!
Ted (92TT)
20:10:25 08/01/14
Re: Re: Swapping plugs seemed to move the problem!
Z32CheekiBreeki
22:42:53 08/01/14
Z32CheekiBreeki
22:48:40 08/01/14
Re: Can a Z run "well" on only 5 cylinders?
Z32CheekiBreeki
12:29:58 08/01/14
You need to OHM test the injectors (s/b 10-14) (n/m)
300ZMang
13:14:35 08/04/14
